Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley help
Thread: Holley help
Old 05-10-2012, 03:51 AM
TommyK TommyK is offline
How do the plugs look?
Does the car drive OK during normal driving when you aren't into the secondaries?
Try backing the screws out 1/4 at a time and test drive with the secondaries disconnected and wired shut and check plugs.
Once you are confident the primary side is dialed in it will be a combo of accelerator pump shot and spring to get rid of the stumble when you stab it.
