Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley help pls
Thread: holley help pls
Old 04-03-2013, 07:22 PM
bygddy bygddy is offline
Proud LOSER
Originally Posted by spinn View Post
Take advantage of the opportunity , and upgrade the carb.
Soaking it should get it loose. The paper will soften.
When replacing the throttle plates , you can use some thread locker, and grind down the screws to not stick out so much.
The idle system is sensitive. You do not want holes in the throttle plates. Demon carbs had real nice thin throttle plates and short screws. I heard stories of people drilling those. Oops.
Yah, gonna soak overnight at the shop tommorow in varsol, then seperate and clean them up, as for the throttle plates will likely just jb weld the drilled holes closed with a very thin skim across them then smooth them off.
