Holley Idle adjustment problem/question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2010, 10:47 AM
I just rebuilt a Holley 6619-1.
This is a used carb that I never used before.
The idle ajustment screws work best when they are out only about 1/2 turns.
Idles nice.
The engine then runs smooth.
The dwell and timings are correct.
The engine is a Studebaker 289.
I always had Holleys that used idle adjustment close to the recommended 1 1/2
turns out.
Will this be a problem.
If yes what is there to do about it?
Thanks
Paul
Old 07-12-2010, 06:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Idles nice.
turns out.
Thanks
Paul
The carb you have has an idle set-up where the screws work "backwards" from a regular Holley carb like a 4150/4160.
So, being as how this is a replacement-type carb, it actually has a lean idle circuit, so you're at the rich end of the adjustment.
Not to worry, though. As long as you are set to the highest vacuum reading or highest idle RPM, you are good to go.
Old 07-12-2010, 06:55 PM
F-BIRD'88's Avatar
Yada Yada Yada
Holleys recommendation is a starting point to fire up a new setup not the "best" number of turns of the idle mix screws.
Read the directions again. Set the idle screws for best idle manifold vacuum and rpm once fully warmed up. As said those idle screws work bas-akwards on that carb..
Old 07-13-2010, 06:56 AM
Thank you both for the help.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
cam questions novaboy72 Engine 4 05-28-2010 01:33 AM
tri carb idle adjustment kbyounger Engine 3 05-19-2008 04:40 PM
Performance cam with a 2 corner idle Holley DP 650 Mad Maggot Engine 15 08-02-2005 06:04 AM
Idle adjustment - holley 650 dp 4777 Toyman Engine 5 07-30-2005 07:07 PM
