Holley idle circuit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2007, 08:27 PM
Holley idle circuit
I thought I knew these carbs pretty well but I've been playing with the idle circuit on a Holley 4777 650 Double Pumper and have downsized the idle feed restrictors which really helped to lean the mixture at idle, but did this modification also lean out the fuel that flows through the transfer slots? or is that supplied by the main well?
Old 08-18-2007, 09:05 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Holley's "A Look Inside Your Carburetor" explains and diagrams the idle circuit pretty well. See page 2.
Old 08-19-2007, 08:43 AM
Thanks, that explains it-the idle curcuit and transition circuit are both adjusted by the air/fuel mixture screws or by modifying the airbleeds and idle fuel bleeds. Interesting.
Holley carb idle GCD1962 Engine 1 07-04-2006 07:44 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
inline high idle? Any Holley tuners out there? sicksixseven Engine 5 08-04-2005 02:41 PM
Performance cam with a 2 corner idle Holley DP 650 Mad Maggot Engine 15 08-02-2005 07:04 AM
How to get Holley to idle down shockers69 Engine 7 01-31-2004 03:18 PM
