Holley Idle mixture screw help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2009, 04:04 PM
I have a Holley 600 on my mild 400 smallblock chevy. I'm also running a descent size cam and that is making the tuning difficult. I couldn't get the idle mixture screws to adjust and I figured out the transfer slots were exposed. I opened the rear secondaries a little and some adjustability has come back. However it is in only one idle mixture screw. If you srew one side in all the way the engine will die. When you screw the other side in it will keep running. I just rebuilt this carb and blew out all of the passages. Would opening the secondaries anymore help? What about drilling the front throttle plates?
Thanks for your time and help.
Old 01-27-2009, 04:12 PM
dawg's Avatar
NAVY VETERAN
a 600 cfm on a 400 is quite small on a oem 400 and one with a cam is really too small.
I seen this problem before and its caused by using the wrong metering block to carb body gasket.
your blocking a hole that should be open.
my guess is on the side that has no change.
get the right gasket for your carb and it should fix it.
Old 01-27-2009, 07:03 PM
holley
Was it working before? Try removing the idle screw and spray carb. cleaner in it and blow it out alittle w/ lower pressure air. Or the air bleeds down in the air hone may be dirty also. Just a suggestion..
Old 01-28-2009, 12:05 AM
It has a Comp Cams XE284.
Thanks again
Old 01-28-2009, 07:30 AM
yes, more timing will help a lot.
I would run as much initial timing as you can (right before the starter starts to complain when turning over a hot engine) then use the vacuum advance on the manifold source. should be between 16 and 20 degrees initial then another 10 to 14 from the vacuum advance. So and idle timing in the mid 30's will make the idle rpm increase a lot which will allow the idle screws to be should down so the blades are in the slot.
Old 01-29-2009, 01:47 AM
Thanks for the replies. I will bump up my initial timing and see if that helps. I did replace my 6.5 powervalve with a 5.5. I guess I should have went lower. In the past I have had hot restart problems with this engine. it doesn't seem to like alot of initial timing. However my 11-1 CR doesn't help.
Thanks again guys for your help.
Old 01-29-2009, 09:10 AM
Technical Support Barry Grant
As some of the other guys mentioned get as much base timing in it as possible and make sure the transfer slots are open no more then .020. If after doing both of these you find it still will not idle with them at .020 or less then you will probably have to drill the holes in the butterflies to get them back down. Starting with our Speed Demon we added the idle-eze feature for cams with durations of .220 and above which allows you to open a valve in the baseplate to get the butterflies back down but with the Holleys you still have to drill. More then likey what you will find when you pull the carb off is that you have gone past the .020 on the transfers slots and when you do this you start to pull that fuel out as well. At that point the mixture screws become ineffective for the most part. Hope this helps.
Old 01-29-2009, 12:42 PM
Thanks for the replies and help. I pulled the carb off and I noticed since I opened up the rear secondaries the front transfer slots are where they are suppose to be. It still seems to run really rich at idle and like I mentioned before, one idle mixture screw has no effect when you adjust it. I'm going to pull the front bowl off and make sure the gasket is the right one. I'll also blow thru the passage again to make sure its not plugged. I drove my car down the road with the one mixture screw turned all the way in. It ran ok, but hesitated when you snapped open the throttle. The engine should have died when I had the one side turned all the way in.
My combination is a 406sbc, 215 Dart Iron Eagle heads, 11-1CR, Weiand X-celerator intake, Comp Cams XE284 cam, and a Holley 600. Most would agree I need a good dual plane like a RPM airgap and a larger carb. The intake and carb are off a 350 and are practically new. I didn't have the money to buy a larger carb and better intake, so I used what I already had.
It seems this engine has always run rich. The throttle response is sluggish and the spark plugs are usually wet with gas. I have been using Autolite 25 spark plugs. With my 11-1CR I thought I should use a colder plug, but maybe thats why they foul kind of easy. It also seems bumping up the initial timing causes hot restart problems. I have thought about doing the ignition power interupt switch that F-BIRB'88 mentioned. I'm getting closer to fixing the problem. I do think its a combination of timing and carb.
Thanks to all for your help
Old 01-29-2009, 07:15 PM
Thanks for the reply and help F-BIRD88. My carb is a cheap model 1850 Holley. The jets are stock, I haven't changed them out. I need to check with Dart and see what plugs they recomend. I have an adjustable vacuum in my garage. I have never locked out my timing before. I've heard people talk about that before, how would you do it? I have a stock HEI.
Thanks again for your time
Old 01-30-2009, 01:41 AM
Thanks once again F-BIRD'88, your help is very appreciated. As soon as it gets above freezing I'm going to start on my distributor and carb. At least now I have a direction to go.
Thanks again for your help
Old 01-30-2009, 04:59 AM
dawg's Avatar
NAVY VETERAN
LOL i guess everyone else he didnt bother to thank.
Old 01-30-2009, 01:30 PM
I thought I thanked everyone. F-BIRD'88 was the last to help and he has given me alot of help. I thought I would think he personally.
Thanks to all!
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 08:40 AM
vaccum too low?? 357 with comp 280H cam 357 Cutlass Engine 16 06-29-2008 10:26 AM
running no vacuum advance oregon chevelle Engine 28 02-07-2007 07:17 PM
idle mixture screws 72Orange Engine 14 09-28-2006 01:30 AM
