It's a 4160, came originally w/a 85 power valve. If it's been sitting, it needs freshening up anyway (renew kit #37-119), so when you are in there, put a power valve in that matches the engine.
It's jetted 63 on the primary side, w/a 39 secondary metering plate (equals a 69 jet). The accelerator pump nozzle was a 0.031". Came w/a purple secondary spring. Good luck. |
Actully a friend of my son needs a carb for a 351 ford... just a street DD... and I didn't want to have him take it if they were junk... I know it needs a kit...ideas on what is it worth? Thanks
It's jetted too lean for a 351. Primary jet's need to be 122-66, secondary plate needs to be 134-9, with a 125-65 power valve. The 37-119 kit will rebuild it but doesn't come with new jet's or secondary metering plate.
![]() You can find 600 cfm 4160's on craigs list for around 25 bucks that are rebuildable.
While the 1850 Holley 600 cfm 4160-type carb (similar to yours) is jetted 66 primary/#9 plate secondary, it's all but impossible to say exactly what will end up being needed. I would just try the carb as-is, or nearly so- w/a power valve that's 1/2 the idle vacuum w/the trans in "D", or neutral if a stick shift. The original #39 plate will likely be fine on the secondary side, you might (or might not) need to jet up the primary side- but I would run it first to get a baseline before changing things too much- maybe go up a size or two on the primary jets if anything. No rebuild kit that I know of comes w/jets (excepting custom kits made up by the specialty carb shops), some do come w/PV's. |
From HERE:
![]() The only drawback to this carb is the check valve for the accelerator pump (the one located in the pump diaphragm chamber) is a "ball and bail" type, they have to be carefully cleaned and checked for proper operation. The later style check valve was a rubber "umbrella"-type valve. But the carb is still fine to use. From HERE: ![]() BALL AND BAIL ON LEFT |
| Holley List # 4280. Carb ID and value? | Cknarf | Engine | 1 | 09-07-2010 12:38 AM |
| Rodding to do list? | advanced design | Hotrodding Basics | 5 | 05-27-2006 04:51 AM |
| edelbrock vs. holley carb | Super Chevy | Engine | 43 | 01-21-2006 09:55 PM |
| Crankshaft Coalition: Master List of Hotrodding Forums | Jon | Hotrodders' Lounge | 38 | 01-20-2006 10:47 AM |
| Hot off the press on the Do-Not-Call... | 68Impala | Hotrodders' Lounge | 0 | 09-27-2003 12:42 AM |
