Holley Mechanical fuel pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2010, 12:44 AM
muddi1's Avatar
Ok, I have installed a pressure regulator and not fired the engine with it in place yet. I just got my lines all bent and everything locate dthe way I want.
During this process I discovered that the bottom seal on my Holley 12-454-11 mechanical fule pump seems to be leaking oil. Its not a huge leak but it definatly leaks oil from this area. No leaks from the mounting point on the block, no leak from the valve cover down the block.
I cant think that this is normal. From what I understand these fuel pumps can be rotated to put the out feed any place needed/wanted. I have not done this and have cchaecked that the screws that hold the "top" of the pump together are tight, not over tight but definatly not loose.
Has anyone else experienced this ?
I am building a 454 with an 7 quart pan, 8 quarts total in the engine with a filter.
Old 10-16-2010, 08:08 AM
DoubleVision's Avatar
The pump gets what little oil it does from the engine. If it`s leaking now I doubt if rotating it will stop the leak. It`ll just move to a different spot. It could be it is leaking from where it mounts to the fuel pump mounting plate and just rolling down to the bottom of the fuel pump. As it would seem if there is oil coming out of the pump them oil would be getting in the fuel on it`s way to the carb. But since there`s more fuel pressure in the pump than there is oil pressure it does the opposite, which is contaiminate the oil in the engine with fuel. Pull the dipstick and smell it, if you smell gas fix the pump or get a new one and change the oil. Fuel in the oil will quickly wipe out a engine due to it`s cleaning properties. If you have to install a new pump or you can repair your current one, pack the fuel pump cavity with moly lube. Since the small and big block chevies have no direct oiling system they count on what little rolls down the fuel pump push rod to keep them lubed. Without moly lube in the cavity the pump spring quickly overheats and can cause failure or a pump spring so weak it stops pumping by the time the engine gets to 3000 RPM.
Old 10-16-2010, 10:42 AM
sqzbox's Avatar
My pipes are my music
Just out of curiosity, why are you putting a pressure regulator on a fuel pump that holley claims doesn't need one?
Old 10-16-2010, 12:42 PM
In my experience Squeeze, I`ve fooled with countless fuel pumps. Like a carter electric that said it didn`t need a regulator so I didn`t buy one. I installed it and found the fuel pressure to be 9 psi so I had to buy a regulator. A friend of mine, he bought a edelbrock mechanical pump that said the same thing, it was around 8 psi so he too had to get a regulator. When I`m buying a fuel pump now and it says it don`t need one, I laugh and buy one anyway.
Old 10-16-2010, 01:57 PM
muddi1's Avatar
Well to both responces, I was running VERY rich and shut it down after about 2 minutes if that of run time. I checked the oil and it is still good to go as far as fuel smell or breaking down (I am no scientist so I dont actually know that it hasnt broken down at least some) I pulled the carb that I myself rebuilt .....it couldnt be a carb issue, I finished the rebuild at around 12:30 AM after only 4 hrs sleep...........a peice of the plastic or polywhatevery it is float had actually "chipped" and was sitting on the top of the float. This I assume was causing my "rich" condition.
I had already purchased a regulator and gauge at the advise of Edelbrock Tech support. I changed the oil and fired the motor agian......right about 8 1/2 psi w/o a regulator. Edelbrock Tech explained that a 1409 which is what I am running, basiclly an Edeljet does not like to live over about 6 psi at the very MAX so if I put my regulator near the pump set it at approx. 5.5 psi.
By the time it gets to the carb through the three (3) 90 deg. bends it has to make and the uphill climb of approx. 9 inches up the Big Block I should be sitting at approx. 4.5 - 5 psi. This as explained to me makes for a much happier Edlejet and a smoother more efficent motor.
This is going in my tow vehicle for boat/car/camper towing so efficiency, is a good word lol. Yes 454 Big Block and efficiency used in the same sentence..am I losing it?
Ideally I want to put my gauge alot closer to the carb but at the moment it will have to sit where it is.
Old 10-16-2010, 02:04 PM
muddi1's Avatar
Here is a basic picture of the fuel pump, it has a different outlet style but basicly the same. It seems to me by looking at the picture there is a diaphram that seperates the two parts of the pump. With out tearing mine apart I am wondering if I might have a bad diaphram?
Old 10-16-2010, 04:40 PM
muddi1's Avatar
Its actually a 1904, see the madness I face
Old 10-17-2010, 06:59 AM
sqzbox's Avatar
OK. The 12-454-11 pump is a bit much for your application regulated for 6.5-8 lbs. of pressure. I was looking at the holley electric they have regulated at 6 lbs. and if your pump now continues to give you leak problems, it might be a better choice as far as FP and you could run a block off plate to eliminate the leak. Just anoither option to take into concideration if you haven't already.
Old 10-17-2010, 09:32 PM
muddi1's Avatar
Well I think I actually have two issues now.....the small oil leak and I am still running way too rich even after the regulator. I cant get the thing below 6 psi.
It is supposedly rated 4-9 psi and preset at 7. So at this point I am going to try eliminating both Holley peices, the regulator and the fuel pump and put a stock pump back on and see what happens.
Old 10-17-2010, 09:38 PM
techinspector1's Avatar
Wiki Edits: 326
Good idea.
Old 10-18-2010, 05:40 AM
sqzbox's Avatar
^^^^x2^^^^!
Old 11-11-2010, 03:49 PM
383Eliminator's Avatar
Mehanical fuel pump
What's the difference in sbc and BBC mechanical fuel pumps? Holley has a marine mechanical fuel pimp for BBC but not for the sbc.. Will the BBC pump bolt to a small block?
excessive backfire and flames! also rocker arm knock chevykid90 Engine 53 08-27-2010 05:42 PM
fuel pump and timing cover question 49fordp/u Engine 7 02-07-2008 09:15 PM
Octane Booster Info SLR_65 Engine 46 09-30-2007 10:01 AM
electric or mechanical fuel pump? 77chevy400 Engine 10 01-19-2004 09:04 AM
Question for Edelbrock Performer fuel pump owners HotRodF100 Engine 1 07-20-2002 05:47 PM
