Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley off idle backfire problem
  #25 (permalink)
Old 05-20-2013, 11:57 AM
toddalin toddalin is offline
Originally Posted by gearheadslife View Post
not a holley guru, but didn't holley tech line basicly say the same thing?
and you brushed it off..
have you even tried a smaller shooter than the first one??
I've never discussed this with Holley Tech line or even saw their tech line. In fact most everything I see on the Holleys, from Holley and others, says to use a larger squirter in the event of a bog because they figure it is typically a lean bog.
It is when I saw the article in CarCraft that I considered the smaller shooters for a rich bog and the dyno pulls confirmed this.
You must have me confused with someone else.
The 21 is the smallest made by Holley.
