Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley off idle backfire problem
  #33 (permalink)
Old 05-22-2013, 06:09 PM
eric32 eric32 is offline
One suggestion I did not try yet is using a different metering block. I got a new one and will take this one off and install the new one and see how that does. If it does the trick then problem solved. I will have to wait till next week for that as this weekend taking truck to have timing cover replaced cause I have a seal leak and installing a high volume water pump.
