Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley off idle backfire problem
  #34 (permalink)
Old 05-22-2013, 08:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're using manifold vacuum for the vacuum advance, swap it over to ported. There are cases where the sudden loss of advance at the hit of the throttle (caused by a manifold vacuum-equipped vacuum advance) will cause a *pop* through the carb, similar to a lean condition.
If this is the problem, it can be dealt with so you can still use manifold vacuum if you wanted. But trying it will at least rule out or verify it as the core issue.
