Holley Primaries wont open - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 06:26 PM
My car has been sitting for a while but has always started up before. I checked the entire ignition/starter system and all is working fine. I finally noticed when given gas the jets to the secondaries were working but the primaries were dry. I have a Holley 750 double pumper. Any suggestions as to why this might happen and how I can fix it???
Your help is appreciated!
Old 06-13-2010, 09:34 PM
406 bug's Avatar
9.82 @ 139mph
I think you mean the nozzles were not delivering fuel. The float/and or needle seat is most likely stuck. Try taping on the top of primary bowl with a rubber mallet to free it.
Old 06-14-2010, 09:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A couple thoughts:
Providing the carb has fuel in the bowls (you check by removing the screws on the sides of the bowls. Do this w/the engine off, w/a rag underneath to catch the gas that might leak, and wipe up any spilled fuel before restarting), the diaphragm might have dried out and become too stiff to work the accelerator pump.
The screws in the bowl sides are also where the float level is checked.
Make sure the squirter isn't plugged up. Also, there's a check ball or short rod underneath the squirter (where the accel. pump fuel comes out), check to see that it isn't stuck. The squirters have two thin gaskets on both sides, be sure they're there and not damaged.
From HERE- Another check valve is located within the accel. pump well itself:
Check to see that there's a plastic pump cam on the primary throttle shaft, and that it has a screw in position #1 holding the cam to the linkage.
Pump cam photo (red object seen in the central portion of photo), from an article on adjusting the accelerator pump circuit:
Be sure the adjuster provides about 0.015" clearance at WOT, but no clearance between the adjuster and the pump arm at idle. The pump adjuster is the small bolt w/a spring that loads it against the lever.
Old 06-16-2010, 01:53 AM
Thanks!!
I will try everything you suggested.
I truly want to thank you for the time and effort you took in responding. This was fantastic and totally unexpected. As a first timer on this site I am really impressed.
Thanks Again!
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 07:32 AM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 10:55 PM
Dialing in a holley 2 bbl junkyardjeff Engine 1 12-01-2005 09:15 PM
Holley throttle body Kevin45 Engine 1 06-10-2005 12:46 PM
Holley electric choke adjustment wheel-7 Engine 5 04-27-2005 10:21 AM
