Holley Pro-jection 2D help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 02:27 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I just sent holley this message, if someone can help me I will appreciate it:
I have been using this Pro-jection 2D for more than a year with absolute satisfaction until
now that started running very very rich.
stock 305 SBC, daily driven car, TH350.
when cold it starts fine, but after 30 seconds more or less the pitch of the sound of the
injectors changes and it starts injecting lots of fuel, you can see a lot of it, then it
smokes black a lot and trhows lots of soot out of the tailpipe until seconds later the
engine dies
if cranked at WOT it starts again but even if the throttle is kept partially open the
mixture is so rich that the engine stumbles and dies again, not to mention the big clouds of
soot and black smoke.
It can't be driven around becuase it stalls, I have managed to warm up the engine keeping it
a high idle but when warm things are worse.
The engine is in very good mechanical condition, actually the car has only 45.000 miles on
the clock but I rebuilt the engine less than 5.000 miles ago just to have it perfect, I
installed the pro-jection well after the rebuilt.
I tried lowering the fuel pressure to 9 psi which makes the engine idle, roughly but it
manages to idle, if it's set to 15 psi the engine dies.
I have gone through all the troubleshooting steps of the manual and everything is OK,
coolant temp sensor is fine, I suspected of it the first time but it's in the reccomended
temp/resistance range.
when I first installed the system more than a year ago I made marks in the ECM's knobs in
case they move I won't have to recalibrate the unit, well the knobs remain in the same spots
but still the problem happens, I have tried to recalibrate the ECM but seems like it does
not respond to the adjustments, I have set them to the leanest possision in Choke, Idle and
Main but makes not much difference.
the fuel pressure, delivery volume and return lines are all OK.
all connections look fine, grounds included.
finally I have doubts as the way the injectors sound, the pulse width as well as the
frecuency sound wrong to me.
Please help me solve this problem, I'm a certified mechanic with 17 years of experience but
this one has beated me, thanks in advance.
Augusto.
Old 10-26-2009, 06:11 PM
ericnova72's Avatar
More for Less Racer
Have you checked the throttle position sensor??, it may change as it "electrically" warms up.
If the pulse width of the injectors is changing, the ECM is telling them to. It is either a bad sensor read fooling the ECM or something wrong with the ECM itself.
Father-in-law had the 900 cfm 4-bbl version, never could make it work totally correct on his racy 460 Ford, wouldn't MPH very good in the 1/4 mile.
Refresh my memory, what are all the sensors?? I remember coolant temp, throttle position, rpm is picked up from coil, MAP sensor reads the vacuum, was there Air Temp?
Old 10-26-2009, 06:26 PM
ericnova72's Avatar
More for Less Racer
Also, does the "D" version have an O2 sensor in the exhaust??
Old 10-26-2009, 06:28 PM
Augusto's Avatar
it only has CTS and TPS, no MAP or ATS, has worked very well for street use, and has lots of power, starts and drives away very well when cold in the mornings, gone are the cold start blues that had with the 2GC carburator, this is why I installed this system, fuel economy sucks though.
I just came back from the shop, even tough the CTS's resistance was according to specs I decided to use another one, Holley's sensor has only one connector prong and I couldn't find one around so I grabbed a good one that I had laying in the used parts bucket, it's from a TBI GM truck that has 2 prongs, I connected one terminal to ground and the other to the sensor's wire.
Bingo..!! it worked perfectly..!!
I had to totally recalibrate the ECM tough, the previous settings didn't work with this sensor but the engine runs smooth and the black smoke is gone.
I'll shop around tomorrow to see if I can find a sensor with one wire, if not I'll buy a new GM sensor and connect it as I did today.
any idea of what brand/car uses one wire CTS sensors?
I wonder why the CTS is bad if the resistance is within parameters? I checked it carefully, tested with a thermometer and ohmmeter at various water temps and it always read OK...don't know
Old 10-26-2009, 06:29 PM
Augusto's Avatar
no, mine does not, but holley sells this as an option
Old 10-31-2009, 09:39 PM
About 30 years ago, a friend of mine had a 280Z that would occasionally go dead rich for long periods of time. After months of frustrating several local professional and hack mechanics, I accidentally found that the CTS connector had had its retaining clip (springy) replaced with a bent paper clip (not springy), causing the connector to intermittently disconnect. This caused the computer to think the engine was really really cold, so it told the injectors to dump as much fuel as they possibly could.
Old 10-31-2009, 10:20 PM
Augusto's Avatar
engine started doing the same thing since last nigth... the CTS is brand new, I also tried with an old but good unit, same thing with both, I'm starting to suspect of the TPS, I couldn't adjust it to the 0.65 volts at idle as holley instructs, didn't go lower than 0.75 so the ECU things that it's at high idle thus dumps more fuel than is needed.
problem will be finding a TPS that can be used... importing the part from the USA will be hard and takes some time, I'll check the part stores monday.
any suggestions as what else may be causing this?
Old 10-31-2009, 11:59 PM
ericnova72's Avatar
More for Less Racer
No new ideas here, I thought TPS could be the problem in the beginning. You are probably on the right track.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
Holley HP or pro form DougMN Engine 2 05-07-2007 10:35 AM
edelbrock pro flo/ holley commander htwheelz67 Engine 6 04-05-2004 07:53 AM
pro jection cleaco Engine 1 03-14-2004 10:29 AM
