Holley pro-jection 2D prob, I think? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 03:09 PM
Hi All
I have a small problem with the idle speed of my 5.7 land rover, it has a Chevy 5.7 fitted in place of the old 3.9 lump, but once warmed up it idles at about 1200 rpm unless i blip the throttle then it goes back down to 800rpm, this is not just when its warmed up from cold it happens every time i accelerate. When braking or de accelerating i have to blip the throttle every time to drop the rpm so that it slows down as it should do. i have tried and fitted several throttle return springs, but it seems to be a soliniod fitted to the side of the injection housing (looks like a carb housing) but don't know how or what i have to do to fix it anyone got any ideas. based in the UK in East Anglia so if anyone knows any Chevy/Holley pro-jection specialist in my area cant find any looking in the normal places. Just for info i didn't build the discovery and i think this problem has been with it since it was converted. Is the Holly injection not up to the job.
kind regards
Ray
Old 09-19-2010, 03:42 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Try to get the complete manual available from Holley via internet (google).
Go to a repair shop that works on fuel injection systems which in the US is any car less than 25 years old.
The Holley setup is simple compared to modern FI systems.
Possibly the throttle linkage is hanging up.
Also, try to disconnect the wire going to the fast idle speed solenoid. The solenoid could be faulty. You will lose the fast idle feature but maybe you could adjust the idle speed to work OK.
vicrod
Old 09-20-2010, 04:05 PM
Thanks
Thanks vicrod will have a phone round tomorow to see who will take a look for me may try disconecting it first to see if it will run without it. will look to down load the complete manual from the web site.
Thanks once again
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 09:27 AM
Holley HP or pro form DougMN Engine 2 05-07-2007 11:35 AM
edelbrock pro flo/ holley commander htwheelz67 Engine 6 04-05-2004 08:53 AM
pro jection cleaco Engine 1 03-14-2004 11:29 AM
