Holley pro jection fuel pump wire identification - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 12-29-2011, 08:42 PM
Hi,
I have a holley pro jection fuel pump that I plan to use in a Chevy TBI transplant. I bought the pump used and it did not come with a wiring harness. I need to identify which terminal of the pump is positive and negative so I can hook up the wiring.
If anyone is running this system can you please let me know.
According to the Holley site, there is a red and green wire, red is positive and green is negative. I just need to know how this corresponds to the plug on the pump itself.
Also, I have not found a pig tail plug that will fit in the pump yet, so if you know, that would be a great help also. Holley does not sell the pig tail plug separately.
Thanks.
Recent Modern Electronic Engines posts with photos
Fuel line kit for Holley 4150 and stock fuel pump colin911 Engine 4 09-13-2011 09:24 PM
Holley pro-jection 2D prob, I think? Grazer1 Electrical 2 09-20-2010 04:05 PM
Holley Pro-jection 2D help needed Augusto Engine 7 11-01-2009 12:59 AM
Holley pro-jection 2D Augusto Engine 1 11-15-2007 09:49 PM
Is the Holley commander 950 Pro-jection a good set-up?? hemi43 Engine 3 08-01-2006 06:17 PM
