Holley Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2013, 03:10 PM
Holley Problems
i just got two holley carbs given to me by my grandfather and have no idea what they are CFM wise. the numbers on them are :
d4te-9510ana
list 2156-1
418
c3te-9510-D
list 2156-1
418
2917
Old 01-11-2013, 03:27 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
You can get a pretty good idea by flipping the carb over and measuring the primary and secondary throttle bores at the bottom of the carb.
Here's a chart showing CFM in the 3rd column, primary throttle bore size in the 8th column and secondary throttle bore size in the 9th column.....
Holley Information Table1 2 - Holdenpaedia
Old 01-11-2013, 03:43 PM
JeffB's Avatar
They cross over to Ford part# C9HZ-9510 E this application was used on Ford HD trucks with a 534 engine from 1961-69 some of those old Holleys had a governor they are a 4150 series.
Old 01-11-2013, 07:50 PM
So they are 600 cfm ? how do u know if they have governers? and if they do are they worthless for a hotrod ?
Old 01-12-2013, 12:03 AM
JeffB's Avatar
Can you post a picture of them? Actually they can be used with some upgrades they use the same rebuild kits as the 1850-1 Holley as stated above by tech inspector you will have to measure the throttle bores to determine CFM for sure but they probably are 600 CFM.
Holley problems help! gtipton Engine 35 05-21-2007 08:33 AM
Holley problems... chrisflock Engine 12 03-27-2007 04:15 PM
holley carb problems aceofspades49c Engine 7 08-09-2005 06:58 AM
holley problems lilbandit3 Engine 6 08-24-2003 07:20 AM
Holley problems HotRod63 Engine 3 12-17-2002 08:25 PM
