We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 12-17-2002, 04:24 PM
HotRod63 HotRod63 is offline
New Member
Post Holley problems
I have a holley 4160 with vacuum secondaries and I have a problem. I hooked up a vacuum guage and i got my highest reading with the air/fuel screws turned all the way in. I didnt think it should even run with the screws turned all the way in. so if anyone can help me i would greatly appreciate it.
Old 12-17-2002, 04:42 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Post
Carb is too rich at idle. Probably the power valve
Old 12-17-2002, 06:17 PM
bullheimer's Avatar
bullheimer bullheimer is offline
"al Qaida live in a Nebula"
Post
1st make sure fast idle screw isnt making contact, make sure floats level is correct. is your throttle plate shaft straight.
[ December 17, 2002: Message edited by: bullheimer ]</p>
Old 12-17-2002, 08:25 PM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
Post
What kind of cam are you runnin' (you might be exposing the idle transfer slots). Also check the idle circuit air bleed holes that are in the top of the choke horn (inside choke horn toward front of carb, make sure they're not plugged up).
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
