Holley problems help!
i recently bought a holley 1805 650 cmf carb for my 68 chevy PU. I installed it last night along with an edelbrock performer intake, but i ran into problems at the end when I tried to start her back up. whenever it turns over a few time, the carb spits gas out of the top fuel bowl where the air cleaner is. anyone know what might be my problem? this is driving me crazy.
)Is it coming out of the little vent tube or the venturi's? If its the venturi's you probably got it 180 degrees out of time, which is easy to do. |
it is coming out of the float bowl vent on the top, from under where the air cleaner would be. would vacuum lines hooked into the wrong places cause it? im stressing hard about this. i though i hooked everything up correctly. how do I unstick the float? or where do I check for a wedged object? I didnt use any thread tape on the fittings. im a newb.
i have never been into a car carburator.. but i've taken down countless fourwheeler/small engine carbs..
if your float is stuck.. take your carb out.. and where the float is.. it has a pin and a needle .. move the float enough to free it up.. and give it a little lube.. but make sure its moving.. and if something is wedged in tehre it will be inbetween the float and the carb body..making the float stick down.. so its letting more gas in and it wont float to the top to stop it.. -my 2 cents worth |
If this cures the problem, you will need to set the float level, by taking out the little brass screw located on the side of the float bowl and raise or lower the level with the afore mentioned nut ( clockwise on the nut lowers the level counterclockwise raise the level) so the fuel just barely starts to trickle out of the hole. |
okay. seriously, thanks a bunch for the help. im going to go give it a try momentarily. ill take some pics. i dont even know if you can post pics in these forums.
You may need to adjust the floats. Holleys have externally adjustable floats. There are several threads here and numerous places on the internet that can explain how to accomplish this
adjusting the floats wouldnt be as work intensive? lol, i think you can tell that I havent worked with many carburetors.
Taking the bowl off a Holley takes 5 minutes............Do it and see if the needle and seat have dirt in them.
Ontario Rodders |
ya i did mess with the distributor, and I tried to mark where it was at but who knows how close I got. i will try. im about to walk out and go work on it now. im not exactly sure where to adjust the floats at, but im going to just start messing with stuff i guess.
here is a link to float adjustment.
Float Adjustment |
Ignition timing will not cause fuel to pour out of the bowl vents.
thanks that will help tremendously. i cant get the secondary fuel bowl off. i though it was only the 4 bolts.
edit: ya i definatly cant get the fuel bowl off. anyone know the 1850 model and how to get it off? i thought it was only 4 bolts. i dont want to pry and mess it up. Last edited by gtipton; 04-30-2007 at 06:52 PM. |
Gasket is probably stuck, yo can take the nedle and seat out through the adjustment hole without taking anything apart I beleive.
| SBC problems.. Its slow | Andyrew | Engine | 80 | 08-18-2007 08:04 AM |
| edelbrock vs. holley carb | Super Chevy | Engine | 43 | 01-21-2006 09:55 PM |
| 455 Oil Problems On New Rebuild | hotrodder442 | Engine | 10 | 07-01-2004 05:10 PM |
| holley problems | lilbandit3 | Engine | 6 | 08-24-2003 07:20 AM |
| holley carb tuning problems | 72 chevy elcamino | Engine | 9 | 08-11-2003 02:45 PM |
