-   -   holley or q jet (http://www.hotrodders.com/forum/holley-q-jet-202482.html)
badknuckles 07-22-2011 09:47 PM
holley or q jet
i currently have a qjet on my 72 318 satellite that now needs a complete overhaul. i have been offered a 3310 holley carb that needs a re build for 50$.
im tempted but have no experience with this particular holley, is it worth the extra few dollars to go with this holley and has anyone had experience with this carb?
JeffB 07-23-2011 02:03 AM
First the 3310 is 750 CFM,too much for a 318 it is also a square bore carb which means you would need an adapter and spread bore to square bore adapters are bad for flow.I would pass on it and get your carb rebuilt.
badknuckles 07-23-2011 02:33 AM
My qjet is square bore also, the engine had a 270h cam intake and headers. I'm also picking up a set of heads which is why I was thinking 750.
FmrStrtracer 07-23-2011 08:01 AM
Q-Jets are spreadbore, 750 or 800 cfm. If its a squarebore, then its an early/mid 60's Rochester(not Q-jet)
va4cqd 07-23-2011 08:09 AM
qjets are all spreadbore. are you sure its a qjet?
va4cqd 07-23-2011 08:12 AM
could it be a carter thermoquad? they were original equipment on mostly Chyrsler products from 1971 to 1985.
joe_padavano 07-23-2011 12:57 PM
Could it be that the O.P. doesn't really know what he has?
JeffB 07-23-2011 01:32 PM
I would like to see a picture posted of it top and bottom so we all can I.D. it,I have a Holley spreadbore from a Mopar motorhome sitting in the garage.
badknuckles 07-24-2011 06:46 AM
I meant spreadbore, its a typical qjet off a late 70's chevy
va4cqd 07-24-2011 08:16 AM
a properly rebuilt qjet would get better fuel mileage
