holley or q jet - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 09:47 PM
badknuckles's Avatar
you talkin to me?
holley or q jet
i currently have a qjet on my 72 318 satellite that now needs a complete overhaul. i have been offered a 3310 holley carb that needs a re build for 50$.
im tempted but have no experience with this particular holley, is it worth the extra few dollars to go with this holley and has anyone had experience with this carb?
Old 07-23-2011, 02:03 AM
JeffB's Avatar
First the 3310 is 750 CFM,too much for a 318 it is also a square bore carb which means you would need an adapter and spread bore to square bore adapters are bad for flow.I would pass on it and get your carb rebuilt.
Old 07-23-2011, 02:33 AM
you talkin to me?
My qjet is square bore also, the engine had a 270h cam intake and headers. I'm also picking up a set of heads which is why I was thinking 750.
Old 07-23-2011, 08:01 AM
Q-Jets are spreadbore, 750 or 800 cfm. If its a squarebore, then its an early/mid 60's Rochester(not Q-jet)
Old 07-23-2011, 08:09 AM
qjets are all spreadbore. are you sure its a qjet?
Old 07-23-2011, 08:12 AM
could it be a carter thermoquad? they were original equipment on mostly Chyrsler products from 1971 to 1985.
Old 07-23-2011, 12:57 PM
Could it be that the O.P. doesn't really know what he has?
Old 07-23-2011, 01:32 PM
JeffB's Avatar
I would like to see a picture posted of it top and bottom so we all can I.D. it,I have a Holley spreadbore from a Mopar motorhome sitting in the garage.
Old 07-24-2011, 06:46 AM
you talkin to me?
I meant spreadbore, its a typical qjet off a late 70's chevy
Old 07-24-2011, 08:16 AM
a properly rebuilt qjet would get better fuel mileage
Holley 650dp holley 750dp dave350v8 Engine 4 10-12-2010 09:45 AM
removing old holley gasket material & couple other holley questions darkostoj Engine 6 06-30-2009 07:06 AM
800# for holley Hot_Rod_Faith Engine 2 07-19-2004 01:09 PM
Holley TBI worknprogress72 Engine 8 09-08-2003 10:49 AM
Holley 94 stromberg 97 Holley 94 BruiseAndy Engine 1 03-28-2003 03:12 AM
