Holley Rebuild Issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2009, 12:07 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I am rebuilding my first holley its a 4150, 650cfm. While reassembling there was a piece missing on the secondary metering block but it was there when i took it apart and can't find it anywhere. Not exactly sure what it is. Its a little silver ball that seems to get pressed into the bottom of the metering block. Any input? This is the rebuild kit i got HLY-37-485. I am pretty sure its the right one cause i emailed my list number to holley and thats the number they gave me. I will upload a pic as soon as my email comes back up.
Old 10-22-2009, 03:18 PM
It's probably the check ball for the accelerator pump that is in the fuel bowl, some fuel bowls have the ball and some have the rubber check valve. But the check balls seldom come out on their own as they are held in by a little brass strip that keeps them from falling out.
Old 10-22-2009, 10:54 PM
Listen and Learn
Wiki Edits: 7
its not on the fuel bowl. its on the metering block. Heres the pic of the bottom of the rear metering block.
Old 10-22-2009, 11:10 PM
airboat's Avatar
It normally doesn't come out. I'm not sure what they use to plug it, aluminum ball or lead shot. Maby a little epoxy for good measure? Just needs to be plugged and whatever you plug it with shouldn't leak gas or obstruct the ports.
Old 10-23-2009, 12:33 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
That is the passage for the accelerator pump. That hole is supposed to be plugged. I think it's like a half round aluminum piece pressed into the opening just barely below the surface.
Been a while since I've done serious work on a Holley.
Old 10-23-2009, 01:07 AM
If that were to happen to me, i would tap it with a tapered tap. a size like 8-32, or 6-32, what ever size fits the best. don't tap in very far, and then get a set screw from a hardware store. use some red loctite so it stay put. just what i'd do.
Old 10-23-2009, 07:31 AM
Listen and Learn
Wiki Edits: 7
I like biscuits idea
Old 10-23-2009, 07:35 AM
302 Z28's Avatar
I have sealed that hole with a piece of lead about 1/8" thick and slightly larger than the hole to be plugged. Mix up a small amount of epoxy and place a smear on the bottom of the piece of lead. Place the lead over the hole and tap it in with a small hammer until it's flush with the surface. remove excess lead and your done.
Vince
Old 10-23-2009, 08:48 AM
Listen and Learn
Wiki Edits: 7
do you think solder or a bb will work?
Old 10-23-2009, 09:43 AM
302 Z28's Avatar
I would not trust solder, and I sure would not trust a BB. The lead method is what was there originally.
Vince
Old 10-23-2009, 09:53 AM
Listen and Learn
Wiki Edits: 7
alright thanks again guys. I will go digging through my buckets of scrap metal for some pieces of lead.
Old 10-23-2009, 09:54 AM
airboat's Avatar
Do you have a gunshop nearby that has shotgun shell reloading supplies? perhaps they would be willing to part with one pellet?
Old 10-23-2009, 02:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A little hard to make out if there's meat enough, but if so it can be threaded for a set screw. And a dab of locktite.
Old 10-23-2009, 02:13 PM
Listen and Learn
Wiki Edits: 7
i have a friend who shoots trap and they reload their own shells. I will see if i can take some bird shot from him.
Old 10-23-2009, 06:41 PM
airboat's Avatar
Hey! I'm not a drummer but a Bass player. anyhow I need cymbals for the kit in my studio, Outgoing drummer took his and my kids want to play too! Just nicer to have everything setup all the time! any advice?
383 SBC Bearing Clearance Issues. Fresh Rebuild. V8 Super Beetle Engine 12 04-21-2012 12:00 PM
Holley Carb Help? (ID + Rebuild Kit) xelysianplainsx Engine 6 12-28-2004 06:41 PM
holley carb rebuild ??????? joe28boxer Engine 8 10-07-2003 11:16 PM
holley 600 carb rebuild TheViper Engine 2 09-16-2003 10:52 PM
holley 1 barrel rebuild diagram fordracing Engine 2 04-03-2003 01:18 PM
