Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Running Rich
Old 12-11-2008, 02:02 PM
Silver00V6 Silver00V6 is offline
http://www.yearone.com/serverfiles/f...13VF73496&trk=
Engine Specifications:
·Horsepower: 400+
·Torque: 400+ ft/lbs
·Compression ratio: 9.5:1
·Dyno-tested: Yes, includes balancer and 14" flexplate
·Dyno sheet: Included with engine's output
·Vacuum produced: 12hg @ 800RPM
·Recommended fuel: 92 octane
·Max recommended RPM- 6000
·Block: Seasoned 4-bolt iron
·Crankshaft: Nodular iron
·Pistons: Hypereutectic
·Connecting rods: Powdered metal
·Camshaft- Hydraulic roller
·Valve lift:.520"
·Duration @ .050" (int/exh): 218deg/228deg
·Rocker arms: Stamped steel 1.6:1 ratio
·Cylinder heads: Ported Vortec
·Valves: Stainless steel 2.02 int/1.60 exh
·Valve springs: Heavy duty
·Bore x Stroke: 4.030" x 3.48"
·Intake manifold: Dual-plane aluminum
·Oil pan, timing cover, valve covers included
·Engine fasteners: High tensile strength
·Warranty: 12 mth/12,000 mi
