Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Running Rich
Old 12-11-2008, 03:32 PM
Silver00V6 Silver00V6 is offline
thorttle blades on botht he primary and secondary are closed. Thats was thought to be the problem last time when i found out the timing was messed up. i am seriously getting tired of this carb. the 80508 is just a 3310 vac secondary with an electric choke. 4160 style carb. The passenger side idle screw works like it should but the driver side does not. The driver side will not kill the car when turning it in to lean it out, but if you richen it it works fine.
