Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Running Rich
Old 12-11-2008, 04:22 PM
Silver00V6 Silver00V6 is offline
read above my vac with the advance plugged up is 30 degrees. Both primay and secondary butterlfies are closed. the only idle screw that will kill the motor when going lean is the passenger side the driver side will do nothing but will go rich if you turn it out. I have tried the wire thing in the idle feed restrictors and it is still rich smelling. Float level and everything else is correct. I have had this rich idle problem since the day this carb was taken out of the box. I bought it brand new threw summit 2 years ago
