Holley spreadbore carb on stock cast intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2014, 05:54 AM
Buick b4's Avatar
Hi.
My Qjet gives me not good performance and mileage,I rebuilt it last year but nothing happened.
Would it be a good idea to bolt a new spreadbore single inlet Holley on stock intake? Is there any advantage in buying an Aluminum intake?
My engine is a 1976 stock Chevy 350!
Old 03-18-2014, 10:38 AM
Originally Posted by Buick b4 View Post
Hi.
The spread bore Holley will fit the Q jet intake. Aftermarket aluminum intakes are usually sought to improve power which tends to be upper end rather than across the RPM range. They do cut a few pounds off the engine but unless this is an FE block Ford the weight savings isn't very large.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
Buick b4 (03-18-2014)
Old 03-18-2014, 02:12 PM
Buick b4's Avatar
I checked Jegs website and they offer remanufactured Qjet!
I always heard that good built Qjet will outperform any other carbs so i guess it should be a good idea to buy a good Qjet instead of changing intake or buying a Holley!
The initial timing is set on 10 and every thing works well but throttle response is not as good as it was in past.
Old 03-18-2014, 07:13 PM
A properly set up Q Jet should give good performance on a 350 Chevvy. As for the fuel mileage, how much does a 76 chevvy weigh. Some of the older cars i know for a fact give very good gas mileage but in 76 the emission controls caused a loss of mileage. I know in 1966 i had a Pontiac Parisienne 2 door hardtop with a 396/ 325 HP & 4 spd. tranny and it gave 28 MPG on the highway. Emission controls are costly.
The Following User Says Thank You to 51 styline For This Useful Post:
Buick b4 (03-19-2014)
Old 03-19-2014, 02:39 AM
Buick b4's Avatar
It is a 76 Nova,We don't need emissions here so how can i get rid of all emission controls ?! should i change any parts?
Holley spreadbore + edelbrock squarebore intake q's Bad66 Engine 7 04-29-2011 04:47 PM
Holley Contender Intake VS Stock clicketyclack Engine 6 07-17-2010 10:45 PM
Holley Spreadbore godsMistake Engine 3 11-07-2007 01:02 AM
What's the best stock cast intake savman1 Engine 17 07-02-2005 05:14 PM
Stock 350 4bbl Cast Iron Intake Dimensions Houman SS '70 Engine 18 05-14-2005 05:06 PM
