Holley squirters - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 09:25 AM
kleen56's Avatar
Holley squirters
I was reading a few article in Shelby American that several people who own the Holley carb are increasing the size of the squirter nozzle in the primaries and secondaries. Those who were running .28 went with .31 or even .35 on the nozzles and stated that their performance and acceleration increased tremendously. It also eliminated the hesitation on hard acceleration. Any ideas or thoughts before I go out and purchase nozzles?
Old 03-18-2009, 11:23 AM
T-bucket23's Avatar
Wiki Edits: 26
There is no canned answer. If you are not having an issue you probably will not see any difference. If you are experiencing a stumble then it may or may not help. A carburetor is something that if you dont know what you are doing and why you are doing it you probably will make it worse.
I dont see and real performace to be gained by upping the squirter size. The first adjustment is usually the pump cam or actuator. I would look at these if you are having a stumble issue first.
Chet
Old 03-18-2009, 07:04 PM
nitro_baller4692's Avatar
floppers forever
here is some info that might help explain things
http://holley.com/data/TechService/T...ech%20Info.pdf
Holley 660 center squirters Tics60 Engine 7 02-08-2009 10:16 AM
Holley Carb FUN (for Barry Grant Guy also) PutPut72 Hotrodders' Lounge 21 10-24-2008 09:35 AM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
Where to buy Holley squirters online? brian400ex Engine 1 04-02-2004 10:30 AM
