Holley Street Avenger?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 09:09 PM
327NUT's Avatar
Ok, just sold my beloved 331" sbc...guy made me an offer I couldn't refuse....literally. I have a '75 508" Cadillac (in pieces) that will replace it, the engine came with the original Q-jet which I like but man is this one butt ugly.
"Maximum Torque Specialties" (Cad only performance shop) uses the Holley 870 Street Avenger on a lot of their builds, they like them. So for those of you that have experience with them....good or bad, lets have it! I guess I'll have to change my name to "508 NUT"
Old 09-17-2010, 09:33 PM
DoubleVision's Avatar
I liked it okay, but it was a typical Holley carb to me. I stopped fooling with Holley`s years ago personally, as most of them are ultra cheap made junk with quality control that was completely out to lunch. So I went back to what I knew and love, Quadrajets.
Old 09-17-2010, 09:49 PM
NOlowrider's Avatar
US Navy-Retired
I have used SA (770's) on two different builds. I have had good expierence with them. Seem to be pretty darn close out of the box. But then again I have had good expierence with all of my Holley's. I have never really fooled with Edelbrock or Q-jets. I tried a Eddy one time, but ditched it real quick after I could not get it to idle in drive. I run two 770's on my blown 468, runs great. The only complaint I have about Holley's, it seems that they get real brittle when they have a few years on them. I cracked two fuel bowl in one week trying to tighten up the fuel inlet nipple.
Old 09-18-2010, 11:22 AM
327NUT's Avatar
Well only 2 replies...not enough, second question is...would a 770 cfm SA be adequate for a 508" engine that will see an occasional blast up to 5000 rpm. This is being built as a street rod engine for cruising but it WILL have some hp and LOTS of torque. Another thought, would the good old reliable 3310 750 prepared properly do the trick just as well??
Old 09-18-2010, 11:39 AM
NOlowrider's Avatar
US Navy-Retired
I would probably step it up one level for a 508. SA 870 would probably be better suited. IMO
Old 09-18-2010, 12:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First choice- Q-jet, second choice, too.
Third would be a 3310. It (or ANY 750 CFM carb) is more than enough carb for that engine @ 5K RPM. Figureing 100% VE, the CFM required is 735.
Old 09-18-2010, 01:17 PM
Take into account that the caddy 500 in 1970 had 500 ft lbs of torque, and it came with a Quadrajet rated at 800 cfm. Of course, this figure was measured in "gross" horsepower instead of the later "net" figures.
Old 09-18-2010, 01:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I cannot say on the 500 Cad, but my '73 472 Cad Sedan de Ville actually came w/a 750 CFM Q-jet.
Opinions on Holley street avenger carbs eric32 Engine 8 09-06-2009 01:50 PM
street avenger and kick down bkt ? THERACER Transmission - Rearend 3 11-17-2008 07:08 PM
bowl inlet to inlet on a 770 street avenger? spinn Engine 1 01-23-2008 11:37 AM
Street Avenger Problem..Uh oh! my350camaro84 Engine 5 10-29-2005 06:51 AM
street avenger chevypunk Engine 2 07-01-2003 08:38 PM
