Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley street avenger problem
Old 03-30-2013, 03:50 PM
wildb's Avatar
wildb wildb is offline
just swapped out carb with working Edelbrock. double check fuel press with 3 different gauges. 3psi at reg exit. pinched by pass hose to see if working. press jumped to +10psi. unpinch press back to 3psi. hooked fuel line to 2nd carb., turned on pump, fuel coming out of vents.
i am working about to have a bald spot on my head from scratching it about this deal...
i thank you for all your input.
i am baffled at the moment....have a cold beer on me & thanks
