holley street domaintor vs edelbrock torqer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2005, 12:12 PM
38chevysedan's Avatar
Rest in peace, Deboard
Last journal entry: 38 chevy sedan
i was wondering which one would be beter to run on the street . i have a 302 with high compression pistons and mild cam. I was wondering which one would make more low end power, i would appreciate any responses on this
Old 03-05-2005, 12:31 PM
DoubleVision's Avatar
Any dual plane intake like the edelbrock performer will make more low end power than a open plane intake. But a 302 isn`t exactly a low end torque monster to start with so if it don`t have some gears to help it out, then going with a dual plane would likely be a better idea.
Old 03-05-2005, 02:06 PM
lluciano77's Avatar
Torker intakes don't have much bottom end or top end.
Your choice is really between the Performer RPM or the Victor Jr. if you are going with an Edelbrock. I like the RPM Air Gap intake myself.
If you do go with the Air Gap get a 2" open hole spacer for it.
I don't know much about the Street Dominator.
Old 03-05-2005, 02:51 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
While the torquer 2 is sortof a mutt by most accounts, the torquer is much better from my experience. I had a 355 with torquer (actually TM1) and pocket ported 461 heads. Had it topped off with a modified 750 Vacuum Secondary Holley. It was a very responsive engine and made great torque as well as pulling good up top. Of course, the old torquers are hard to find anymore.
Chris
Old 03-05-2005, 03:10 PM
lluciano77's Avatar
I have the original Torker 289 on my 5.0 with Trick Flow heads. I would have rather got the Victor Jr. but I got a good deal on the Torker.
You can find them on Ebay all the time. They have the carb sit crooked so if you have the rod type linkage you have to switch to a cable.
I wouldn't recommend one myself.
Old 03-05-2005, 11:50 PM
11secmudtrk's Avatar
mudbogger
a holley street dominator is about like a performer rpm, it ran alright on the 327 in the old 80 silverado we had.
Old 03-06-2005, 05:10 PM
wildman926's Avatar
Never let them see you coming
I just installed a Holley Street Dominator on my son's 350, and I really like the difference from the Torker II that someone else had on the Truck. With the Holley, it has tons more throttle response, smoothness, as it should.
Old 10-25-2007, 11:01 AM
I have a torker2 on my 302. It seems to like 4500 to 5500 rpms the best.
Old 10-26-2007, 01:00 AM
JeffB's Avatar
302 Intake
Based on your setup go with the Holley,actually one of the best intakes on a 302 is the old Edelbrock F4B its the closest to the famed Cobra intake,there is an intake comparison of about a dozen intakes on the internet you'll have to search for it maybe Google:small block Ford intakes Good Luck!(from another Ford Guy)
Old 10-26-2007, 02:19 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'm not a fan of the torker. Its kinda old and I think they hang on to it for nostalgic reasons. An RPM air gap has almost all the low end of a low dual plane with all the top end of a single plane. The torker has none of the low end and none of the top end compared to modern designs.
I don't have any experience with the holley, but I think the torker would be my last choice of any intake unless I had a really hairy nostalgia 289.
Old 10-26-2007, 04:30 AM
If you need to go with one of the intakes you named . I think the Holley will make more power on the low end . But both intakes are very close . I do know a guy thats running a Holley street dominator on a 355SB . He has 12.5 to 1 ? and over 500 lift cam #461 heads . he says 202in160ex valves . And a 850DP Holley . This guy says he loves how the car runs ! This is not the way I like to build engines but he said its dialed in .
Old 04-06-2008, 01:15 PM
know anything about this intake?
Need info on this intake- I want to use it but recieved it in a trade and know nothing about it. RPM range..etc..
ID:	29079   Click image for larger version
Name:	street dom 2.jpg
Old 04-07-2008, 12:27 AM
JeffB's Avatar
Holley Intake
It's an Oldie but a Goodie,RPM range was 1000 to 6500 RPM depending on cam selection.I wouldn't be afraid to run it,you could run a Quadrajet or straight bore carb too.I sold a lot of these back in the 70's never had any issues.
Old 04-07-2008, 07:57 AM
awesome!
the picture is of one just like mine but the one i have was ported for some heads,will that up the rpm range? What happens if i used a carb spacer with it?
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 03:01 PM
Holley carb & powervalve info Frisco Engine 9 06-25-2003 02:47 AM
carb selection 4 in mind, demon holley or edelbrock? Jared Engine 6 06-18-2003 01:55 AM
Holley Street avenger smallblocked_S-10 Engine 1 09-01-2002 03:16 PM
holley street avenger alex Engine 3 09-04-2001 06:08 PM
