Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley systems max camshafts
Old 01-04-2010, 10:12 PM
6sally6 6sally6 is offline
Originally Posted by gas_guzzler
Thanks very much. It comes with a new set of lifters (for about the same price of the cam alone). I have a set of compcams springs that were used on a cam with a little bit more lift than this, I might get them checked out to see if they're ok. If not I'll definately look into those springs.
How lopey would this cam be in a 307 chev (with ported world s/r 58cc heads and 1.6:1 roller rockers)? The only comp cam I could find that was close to this (although definately not the same) was the 30-30 hydraulic. I've seen 302 camaros on utube with the 30-30 cam would it be similar? I was hoping for a 108-110 LSA but I'm sure this will still perform very well.
IF the duration is 232/245 @0.50 even with the 112LSA it will have a nice "gallop".....not Pro-Mod sound but nearly circle track lope. Lotsa duration for a 307.
