-   -   Holley systems max camshafts (http://www.hotrodders.com/forum/holley-systems-max-camshafts-170876.html)
gas_guzzler 01-02-2010 08:28 PM
I've come across a cam for sale but there seems to be no info anywhere about this cam. Here is the sellers description:
Holley Systems Max hydraulic performance camshaft and lifter kit #300-774, grind #41R988, duration @ .050" lift 235 & 242, lift at valve .473" & .488", new in box.
#588/2.
It isn't on the holley website. Does anyone know what the LSA is on this cam? And I presume the lifters would be up to the job? (street/strip car)
gas_guzzler 01-04-2010 04:02 AM
Is any one able to help me with this pleease? It seems strange I can't find any info...
gas_guzzler 01-04-2010 05:45 PM
Originally Posted by F-BIRD'88
I believe its 112.. uses new hydraulic flat tappet lifters.
requires a high perf stock diameter replacement valve spring EG: Lunati #73943
Thanks very much. It comes with a new set of lifters (for about the same price of the cam alone). I have a set of compcams springs that were used on a cam with a little bit more lift than this, I might get them checked out to see if they're ok. If not I'll definately look into those springs.
How lopey would this cam be in a 307 chev (with ported world s/r 58cc heads and 1.6:1 roller rockers)? The only comp cam I could find that was close to this (although definately not the same) was the 30-30 hydraulic. I've seen 302 camaros on utube with the 30-30 cam would it be similar? I was hoping for a 108-110 LSA but I'm sure this will still perform very well.
6sally6 01-04-2010 10:12 PM
IF the duration is 232/245 @0.50 even with the 112LSA it will have a nice "gallop".....not Pro-Mod sound but nearly circle track lope. Lotsa duration for a 307.
6sally6
