Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley two barrel on a chrysler 318 problem
Old 10-09-2003, 08:42 PM
Robinson Robin Robinson Robin is offline
The 318's use a smaller bolt pattern for the carb I ran into the same problem. you can get a 2 barrel from a 360 and it will work with the carb but the ports will be to large to match up to the heads very well and it will hurt flow. I think 4 jaw is right you may have to go with a 4 barrel and adaptor to use the holley. Another way is to get 360 heads too but unless you change the pistions you will have a low compression ratio because they have more volume.
