QuadraJet hands down. It's not as easy to work on as the Holley but the throttle response for street driving and better gas mileage make it worth the effort. Plus there's nothing like the sound of a Q-Jet at WOT.
Sounds like both carbs need some TLC though. If you don't have any experience and plan to do it yourself then start with the Holley, it's simpler to work on. That's assuming the throttle shafts aren't loose. If that's the case save yourself some grief and buy a new or rebuilt carb. I've had good luck with the Summit QuadraJets. |
At this level any properly sized carb will perform about the same. If you have a Qjet and a Qjet intake then use that. If you've never rebuilt any carb one is just as hard as the other. What it would come down to me is cost and since you alreay have the Qjet setup just refreshing that one would be the cheapest and make the most sense.
The most tedious part of rebuilding it will probably be cleaning it. Purple Power and a denture brush should be about the cheapest easiest thing you can use for that. |
The Holley is easier to set up and get it to work mostly because it works pretty well even when not built with particular care. It is much more tolerant of someone still learning about carbs. Besides, parts are available everywhere, it would seem in every grocery store. These are also great carbs and will respond in knowledgeable hands, but they also function OK over a very wide range of not quite right set ups. Bogie |
I rebuilt a q-jet for my old pickup and had to fab a tool for adjusting the float height. it was a simple 14 inch socket 14inch well. and a short peice of 14 copper tubing smashed with a hammer to fit over the small flat head screw driver tipped screw. took some trial end error but it finally worked very well.
No doubt about it, a properly overhauled, setup QJ is the ticket. Unfortunatly there are too many shade tree mechanics who think they are QJ experts. I would venture a guess that there are very few QJ's (short of being new or professionally overhauled) out there that meet the above criteria.
Vince |
If the plugs or seat of the pants says there's more to be done, describe the symptoms and we'll give you some suggestions. Don't forget the ignition during this- the timing curve can effect the way the car runs a LOT. |
Q-jet.
grandpa worked at GM during the day, and fixed cars up at night. Hope he gets to teach me how to tune a q-jet. From what he and my uncle (grandpa's shop assistant) told me he could get the carbs just right and the cars would run like hell. In a good way. |
thanks for ALL the input yall. All info is apprecieated. I'll keep checkin in. Im trying to get pics up. Thanks again and feel free to check back if anything else comes to mind, cause I know I'll proly re-read the replys a few times(got a short attention span). Peace...
I don't know about Holleys, I used to use Edelbrocks, not anymore. Qjets only. Far better carbs. Better throttle response, better starting, better economy, don't have smelly exhaust.
| Holley, Edelbrock or Quadrajet. Opening Can of Worms. | 58lincoln | Engine | 8 | 08-13-2009 07:09 PM |
| Which carb Quadrajet or Holley? | 67firebird | Hotrodding Basics | 24 | 07-14-2008 03:30 AM |
| Holley or Quadrajet | longt | Engine | 23 | 07-11-2008 04:52 AM |
| Quadrajet or Holley???? | colincamaro | Engine | 6 | 04-18-2007 04:59 PM |
| holley / quadrajet question | mshellw | Engine | 3 | 04-20-2003 04:08 AM |
