Hollow connecting rods ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2006, 02:19 AM
Just curious, has anyone ever built hollow connecting rods? What about fabbed/welded rods? It seems you could make super strong light weight hollow rods. I remember a few years back when I was into mountain biking the new thing was shimano hollow crank arms, they where stiffer than standard arms and lighter weight.
Jordon
Old 12-08-2006, 07:20 AM
poncho62's Avatar
Wiki Edits: 5
There is a little more force on a connecting rod than a bicycle bell crank.
Old 12-08-2006, 11:43 AM
Obviously there is more force on a connecting rod but the fact remains that a hollow tube is stronger than a solid bar of the same weight. Why do you think roll bars are hollow tubes and not solid metal rods?
Old 12-08-2006, 11:59 AM
zipfactor's Avatar
Last journal entry: Just starting
"but the fact remains that a hollow tube is stronger than a solid bar of the same weight"
That is not necessarily true. Hollow tubes have a greater capacity for compression forces than a solid bar. In the case of tensile strength, a solid bar has more strength than a hollow tube. And the longer the member is, the less compression force it can handle. So in my opinion it would be a better idea to go with a solid member vs. a hollow one in terms of what would handle the variety of forces better (compression, tension, etc).
Old 12-08-2006, 12:06 PM
A connecting rod is not subject to large torsional stresses that favor a hollow tube, and a forged single piece I-beam or H-beam is much easier to manufacture and machine.
Old 12-08-2006, 12:14 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Jerking the piston down from the exhaust stroke against the inertia of the piston and vacuum above it is what kills rods. That comes from rpm mostly.
Old 12-08-2006, 12:20 PM
Thanks for the info, I just found this, http://www.engineering.gr/design/hom...?table_show=15
anyone want to do some math? lol
Old 12-08-2006, 01:31 PM
camaroman7d's Avatar
Yes, There are/were "hollow" connecting rods made. I have had a set in my hand before and know a guy that still owns them. Do a search for Mekart, Meckart or Mechart rods. Don't remember how it was/is spelled. They were very light and looked impressive, no real world experience with them though/
Old 12-08-2006, 08:35 PM
327NUT's Avatar
Welded rods??? WAAAAAY back in the day, before all the wazooo aftermarket conn rods came out there was a company called " Dons Boxed Rods" He actually tig welded a boxing plate on both sides of a stock rod, kind of like boxing a frame. Never saw one, must have been very heavy and hell to balance an engine but he made them, used to advertise in Hot Rod.
Old 12-09-2006, 08:54 AM
woodz428's Avatar
Troll Hunter
Ansen used to make hollow rods. I don't recall the material. I think there were some that were titanium.
Old 12-09-2006, 08:57 AM
Here you go, these are a version of Mechart rods. Very similar to the ones I mentioned above for a SBC.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 09:27 AM
5.565 or 5.7 Connecting Rods in 383 Chevy21 Engine 29 09-29-2008 06:25 PM
Powdered metal connecting rods chirpn69 Engine 4 07-12-2006 06:14 PM
BBF connecting rods fourtwoseven Engine 0 03-04-2006 04:15 PM
SBC connecting rods (opinions needed) americanfreedoms Engine 9 09-24-2002 05:06 AM
