holly 1850-2 idle adjustments - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2011, 11:30 AM
hello everybody i recently bought a second hand holley 1850-2 it was in good shape but the throttle bas was broke i changed and put new holley gaskets and all the stuff the problem is that when i close the idle screws on the metering block nothing happens i close it at all and the engine does not shut off i dont know it does not look like is flooding or something what coul be the cause the new platte i put becomes from a 9834-3405 600cfm old carb i do the comparison and they was exactly the same than the broke one
any help will be aprreciated
Old 03-07-2011, 01:54 PM
302 Z28's Avatar
You really must know what your doing when mixing Holley parts. There are various base plate designs and they all appear similar. You must also use the proper base plate gasket for the base plate and base.
You say the carb was in great shape but the base plate was broken , hope you got a great deal on it....like free .
Vince
Old 03-08-2011, 08:55 AM
yes it was almost free i take it just because my other 600 cfm holley carb is too old and i was thinking tha with this one i can have less troubles but as i see im thinking seriously to go back to my old carb it used to work better than this one i put the other baseplate because they have the same number stamped so that is why i decide to put it
Holly 850 DP locking up....wont return to idle stevo68 Engine 4 10-09-2005 10:53 PM
holly #1850 any good? hcker2000 Engine 18 08-26-2004 06:11 AM
1850-3 Holley adjustments 1980Impala Engine 5 06-02-2004 03:31 AM
600 CFM Holley Idle Mixture Adjustments. FBody Engine 3 06-01-2004 11:36 AM
adjustments on a Holly carb wheel-7 Engine 5 09-15-2003 08:28 AM
