Holly 3310 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2005, 08:50 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
Holly 3310 Question
The secondary float bowl is a center float and on the inside is a plate with 6 or 7 clutch screws. The question is there is a gasket under this plate which seals the float bowl and this plate, it that correct?
In the past(on other carbs.) I have removed the bowl and the plate that was in there, and there was a spacer and gasket and then a float bowl gasket which is correct?
I just bought this carb and it is used and I am cleaning it and changing the jets and power valve.
Thanks
Old 02-22-2005, 09:40 AM
engineczar's Avatar
I've rebuilt a few of these and to be honest I've seen them come through both ways with and without that gasket. I always send them out with the gasket and haven't had any complaints.
BSE Racing Engines
Old 02-22-2005, 10:39 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I do believe there is supoosed to be a a gasket there.
Old 02-25-2005, 07:31 PM
lluciano77's Avatar
There are metal plates along with the metering plates on some of the 4160s. I have seen the small gaskets on all of them.
Old 02-26-2005, 10:48 AM
Technical Support Barry Grant
It will vary depending upon when the carburetor was manufactured some had the gasket/shim plate there while others did not. You can run the gasket/shim plate on models that did not come that way, but if the carburetor was originally set up that way, and you remove it, it can cause the rear float bowl to drain down into the engine.
Old 02-26-2005, 01:57 PM
GoneNova/406's Avatar
the holley book and break down picture i'm looking at shows
secondary metering body,metering body plate gasket,metering body plate and secondary metering body gasket.hope this is what you wanted.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about changes i made on my holly carbs??? Robbie Engine 3 07-03-2004 10:49 PM
holly carb float question impala65 Engine 3 03-30-2004 09:44 AM
Holly 4150 question OldBucsFan Engine 11 08-04-2003 09:59 AM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
