Holly 4150 question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2005, 07:29 PM
Just bought a 4150 doublepumper from a buddy. He hasn't used it in a while (great condition) and I have a question about the dual feed line.
Is it supposed to have a plastic piece inside the line to the secondary bowl?
The reason I am asking is because fuel was pouring out of the vent tube at the top when I tried to start it (letting battery charge ATM) I am new to the whole Holly thing. I have lowered the level, and it came over the front now, so I lowered that one. What's up with that?
I just want to get it started! LOL
Thanks for the help,
Tom
Old 07-29-2005, 08:18 PM
lluciano77's Avatar
Holleys originally came with an inline filter before the bowls. It was't made of platic though.
It sounds like there is something either stuck in the needle and seat, the floats need to be adjusted, or the gasket is missing on the needle and seat.
I suggest you read up as much as possible if you are going to run a Holley. They aren't just run and go carbs. It takes years to be able to tune them well.
Old 07-29-2005, 08:50 PM
That's what I was hoping. It looks like there are NO gaskets except on the bottom below the main body. I have gotten it to run finally. (WOOHOO) but I have to hold it almost 1/3-1/2 open just to get it to idle. By the way...I had 8" of vacuum at idle when I was running an Edelbrock on it. I know I'll need a new power valve, but will teh gaskets make that much difference?
Old 07-29-2005, 10:18 PM
lluciano77's Avatar
I ended up going to the Holley 4010. It only has one main gasket that is above fuel level. Less chance for leaks.
With any Holley, a rebuild kit is almost always necessary if the carb has been sitting for a while. Holleys are tempermental. Especially when small particles in the fuel bowl get stuck in the needle and seat.
I think your needle and seat are bad. Rebuild it, clean it, and try running it again. If it is still having troubles well go from there.
Old 07-29-2005, 10:55 PM
I appreciate the help. After getting it to run, I decided to check hood clearance (91 camaro) and it will NOT fit without a hood scoop (or no filter...no way). I will still take it off and do some cleaning to it, but my project had just been put on hold for a while.
Seems like it is becoming more of a PITA to do any good mods to this car, therfore I'll be in the market for some 60's/70's Chevy Muscle pretty soon....I know it'll fit then!
Again...thanks for all the help!
Old 07-29-2005, 11:09 PM
It won't fit with a drop base air cleaner?
Old 07-30-2005, 01:13 AM
Nope...The drop base I have is 2 inches. It was on my edelbrock which barely fit.
Whenever I shut the hood, the Holly's choke blade barely hits it. No room. I might be having a guy buy the body in a few weeks anyway. He's been looking for a few months and just happened to come across mine today.
Old 07-30-2005, 07:43 AM
That sucks
Old 07-30-2005, 07:20 PM
Well...today I went and pulled all sparkplugs, and turned the car over to clean out the cylinders....SPLASH!!! it went from the right side.
Decided to pull the carb, and I noticed that it leaks from a little hole. (Also realized that I never tightened the front right carb bolt down. Doh!! )
If looking at the bottom, w/ the front blow facing up, there is a bolt between and above the mains. Just to the right of that is a hole and it was leaking pretty bad. It almost looks like there is a checkball in there.
Is this the power valve protection?
This also explains why my cylinders filled with gas.
.....and so begins my journey....LMAO
Old 07-31-2005, 01:03 AM
lluciano77's Avatar
It sounds like you are missing the powervalve gasket. Either that or the one you have is bad.
Old 07-31-2005, 01:51 AM
funny you mention that....i took the whole thing apart tonight...the gasket was not on straight!....plus the checkball was stuck. loosened it up, and fixed the gasket...
No leaks now, but i had to drain my oil because it had gasoline in it...flushed the oil system, and now just need new sparkplugs to replace the broken ones...lol my o2 sensor was in the way of #5 plug and i ended iup breaking both trying to remove them.
must say...the holley is simple, yet very complicated at the same time...glad i bought it!
Old 07-31-2005, 06:30 PM
SHE LIVES!!!!
Doublechecked everything. Changed the oil. Replaced the sparkplugs....turned the key.
Now I just need a 4.5 powervalve. This would be correct for 7" of vacuum at idle, right?
Thanks for all the help guys. Between this post and the other 4150 posts, I have definately been taught a lesson in humility.
Tom
Old 07-31-2005, 07:31 PM
lluciano77's Avatar
Either a 3.5 or a 4.5. You will have to see which one it likes better. You want the powervalve to open safely above idle. You also want it to come in early enough to add it's extra enrichment.
Holley 4150 / timing question 70bird Engine 6 04-01-2005 07:19 AM
Holley 4150 question OldBucsFan Engine 1 03-03-2005 08:40 PM
Holly 3310 Question solidaxel Engine 5 02-26-2005 01:57 PM
holly carb float question impala65 Engine 3 03-30-2004 09:44 AM
Holly 4150 question OldBucsFan Engine 11 08-04-2003 09:59 AM
