holly 650 dif 750 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 12:45 PM
holly 650 dif 750
What makes a holley 650 different than a 750. Is it the body, blocks what. I have a 750 and need a 650 was going to get a 650 and but my rear block and boles on it to make it a bubble pumper.
Old 08-06-2008, 09:27 PM
Check out Holley's detailed website. I thought the main difference between the two carb's is the size of the throats and throttle blades but I could be wrong. Also - believe it or not from my experience you can call Holley's 1-800 tech line and they can help you on Holley's "finer points". Good luck.
Barry Grant Speed Demon 650 or 750? Double_v23 Engine 7 01-22-2008 08:11 AM
Holley Carb 750 and 650 70GTOkid Engine 6 07-07-2007 01:09 AM
holly 650 no full return omega69 Engine 1 05-17-2007 12:07 PM
Holley 650 DP Mec Sec or 750 Vac Sec DTL504 Engine 7 12-29-2003 05:25 PM
750 carb vs 600 or 650 mtmniles Engine 4 04-26-2003 04:19 PM
