Holly carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2008, 02:09 PM
Holly carb
Hi guys and girls
can someone please tell me the right way to set up the holly carb on my chevy truck, its a 600 4 barrel with vacuum secondarys it was new when i bought the truck but but the petrol tank was full of rust and clogged it up
i have cleaned it out but now can't get it to run very well, it's a pig to start seems like it's running rich runs fast and and if you slow the idel down stalls when you put it in gear
iv also fitted a high pressure pump and it kept flooding so i put an in line regulator hope some one can help as im at a loss as to what to do next
cheers Bobby
Old 12-05-2008, 03:22 PM
MI2600's Avatar
Member# 3287
1. Carefully unbolt carburetor.
2. Remove applicable linkage.
3. Remove carburetor from intake.
4. Drop in trash.
5. Buy an Edelbrock.
Not to be a smart ***, but it sounds like there may still be some dirt inside. I would disassemble again and vigorously blow out the passages.
holly carb id howardallen Engine 8 07-18-2008 05:03 PM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
holly carb baughman Hotrodding Basics 3 12-16-2004 01:15 PM
???about original specs on a holly carb jetting??? Robbie Engine 5 04-02-2004 08:18 PM
