You would be better off going to a heavier spring in the secondary vacuum diaphragm so it open's later. but you can disconnect it at the bottom of the secondary vacuum actuator where it hooks to the secondary linkage! its a good idea to tie it closed so it cant accidentally open and stick ! Then you will be running off the primary's!
Jester
I see 327 already gave you a good answer! While I was typing LOL
