Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holly carb
Thread: holly carb
Old 07-07-2012, 06:13 PM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
Originally Posted by dirtyfingers View Post
thanks for the reply.After the secondaries are secured shut,will there be a problem with the fuel in the rear bowl ,and would it help to change the 1.7 roller tip rockers that came with the truck to 1.5 roller tip rockers I have hanging in garage,would this help with fule cunsumption
It takes just as much fuel and air to go 60 Mph at 2000 rpm wether its a 4 barrel 2 barrel or 8 barrel the difference is your foot Leave the 1.7s alone If you had valve train work you may have custom sized push rods and other mods!!! Did you just get this truck 1.7 ratio rockers What rear gear in this thing and diameter tires are you running what cam? If you just broke it in how many miles on it since initial cam break in
Jester
