Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holly carb
Thread: holly carb
Old 07-07-2012, 09:41 PM
beachbum0's Avatar
beachbum0 beachbum0 is offline
I was probebly typing as you were. I will check the lift and let you know. Also was told converter is stock and it drives ,from stop and through gears fine. The 350 trans was beefed up for raceing and before I got the truck it had a race engine in it but my brother took out for his project. Then he sold truck to person I got it from and that person got a engine for it but no one knows what it is eccept for what I said earlier. Broke in engine by one hr at 1800 rpm's than seated the rings by loading and unloading for 30 minuts,probebly not more than45 miles on engine. The thing runs goog,strong,no oil leaks temps. good,and on boging or hesitation.If the dial indicater reads around stock cam, and I put 1.5's for rockers,whith the right push rod geometry, will this help on gas consumption?
