-   -   holly carb (http://www.hotrodders.com/forum/holly-carb-54267.html)
baughman 12-16-2004 11:57 AM
holly carb
i have an old holly carb i pulled off of my dads willies pick up the truck has been sitting for about ten years in the shop
anyways i asked my dad what size the carb is and he doesn't remember if it is a 650 750 or 850 heck it could be 10000 as far as i know what im looking for is a way to find out what size it is so i can get the right rebuild kit for it
i took the carb to the local napa here in town they looked at the carb and told me that they couldn't tell what size it was
please if you have any info please help
BOBCRMAN@aol.com 12-16-2004 12:23 PM
On the front of the choke housing, on the right side, there will be several numbers. One set of numbers will read "List-number" such as List-3310-A or List-3418-AAS etc. If you copy down the numbers then relay them to us. Someone on this forum will tell you what you have....
my350camaro84 12-16-2004 12:51 PM
yeah do that or if you take it to an auto parts store. or contact Holley themselves you should be set to go.
Nightfire 12-16-2004 01:15 PM
If you get the number of the carb you can go here http://www.carburetion.com/Number/bynumber.asp to identify it.
Also check out http://www.carburetion.com/carbinf.htm and www.carburetion.com
Mike
