holly carb id - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2008, 06:40 PM
holly carb id
I have a holly 2 barrel carb I am trying to id. the number on the side is R7364A. it is not the typical holly shape. Any help would be appreciated.
Old 07-14-2008, 10:46 AM
T-bucket23's Avatar
Wiki Edits: 26
get the list # off the air horn.
Chet
Old 07-14-2008, 01:30 PM
That would be an OEM Holley number. It's not a performance carburetor.
Old 07-14-2008, 01:50 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Hey since we are talking about this stuff I was looking at a carb I got with a 427T BBC. It was in a dump truck, it is a hollley it has small bowls and metering blocks on both ends but only a single inlet for fuel. It is a vacuum secondary. I thought the list was 4181 or 8141 or something like that. The carb is huge but the butterflys are really small.
Any ideas?
Old 07-14-2008, 06:25 PM
woodz428's Avatar
Troll Hunter
Without a pic, it sounds like it may be a 22XX. They separate at horizontally instead of vertically like most familiar Holley carbs. It that is the model there is little( really none) airhorn to have a list #.They came in several models and one version was used as standard equipment on some Chrysler models in the late 70s. I can't recall all the various # but they some are 2210,2245 and 2280. I'll look through some older manuals and see if i can find that #.
The 4bbl sounds like a typical Holley truck carb, all were single inlet with a transfer tube to the rear, that's if it has the bowls that are removable. If not it may be a 4360. Just like the 2bbl it is horizontally separated. A pic would aid in identifying both carbs.
Old 07-14-2008, 06:35 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Look in the Knowledge Base on this site,
http://www.hotrodders.com/kb/carburetor-tech
How soon we forget.
Luv the smell of NITRO in the morning.
Old 07-15-2008, 07:38 PM
holly carb id
this carb has no choke horn. it is an odd looking holly. thanks for your help
Old 07-16-2008, 08:46 AM
woodz428's Avatar
Troll Hunter
1975-78 Mopar 360 engines,virtually every model car.
Old 07-18-2008, 05:03 PM
holly id
thanks for the information. on my holly carb id question.
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
holly carb baughman Hotrodding Basics 3 12-16-2004 01:15 PM
???about original specs on a holly carb jetting??? Robbie Engine 5 04-02-2004 08:18 PM
