holly carb. issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2012, 05:49 PM
holly carb. issue
just put a rebuilt 4 barrel on a 327 it idles good runs thru the gears ok (auto) but starts bucking like its fuel starved real bad on hills and will stall on a sharp turn. I've adjusted the float with no real change- makin me nuts any ideas?
Old 07-11-2012, 06:34 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Does the carb have sight glasses on the bowls? If not, you need to remove the screw on the side of the bowls, adjust the floats until fuel is at the bottom of the screw hole. Check the fuel pressure.
vacuum issue or carb issue idk for sure chevyok06 Engine 1 07-10-2011 05:19 PM
Holly carb farm truck Engine 6 01-11-2011 07:52 PM
Holly Carb chevy bb 572 Engine 1 08-21-2006 06:41 AM
holly carb. heavy evy Engine 2 10-07-2004 09:46 PM
holly carb impala dreaming Engine 5 02-14-2003 11:15 AM
