Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holly mixture adjusting screw
Old 02-03-2004, 05:02 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
It is a fuel leak or something stuck in one of the passages. Take it apart and clean it well. If it needs new gaskets, get them. Clean out the air bleeds and idle feed restrictions. The problem is in the idle circuit.
Whenever a mixture screw has no effect you can count on it being one of the problems mentioned above. Holleys are extremely sensitive to dirt.
