Holy Carbon Buildup Batman! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 12:48 AM
Finally had some time and did a little tinkering with my 318 Polysphere. I was worried it had been rebuilt since pulling the valve covers off and finding newer gaskets and the springs look awfully new(er) than the rest of the valve train.
My worries faded when I was able to crack into those heads, every gasket I found had no aftermarket indications, everything seemed stock (or what was left of them. Those exhaust manifold gaskets had seen better days.)
So now the heads are off, and wow that's a lot of carbon!
So, what's the best cleaner for removing carbon so I can get a good look at these head to check for cracks? Or am I just going to have to scrub my arms off?
Old 07-14-2012, 08:23 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Carbon in the combustion chambers can be removed with a brass wire wheel in your drill motor on steel heads. Also, almost any engine cleaner will help, Gunk in a rattle can is good. If you pull the valves, stay away from the seats with the wheel.
Semper Fi
Old 07-14-2012, 04:48 PM
Thanks! I'll give it a go!
Old 07-15-2012, 08:00 AM
be sure to wear a dust mask, lot's of lead flying around when cleaning old heads like that.
Old 07-15-2012, 08:53 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Propane torch..heat the carbon until it turns to powder and the wire brush works better then..
Sam
Old 07-16-2012, 10:30 AM
mask and safety glasses; probably best to do it outside.
Me Id take em to the machineshop; have them decrudded and magnafluxed
Old 07-17-2012, 11:25 AM
1971BB427's Avatar
I'd agree! I you went this far to remove them, then have them checked at a shop, and at least have new valve guide seals installed. I'd hate to clean them and reinstall them without making certain the valves/seats and seals are all good to reinstall.
318, carbon build up
Holy crap Batman, it's raining Buicks......... Hippie Hotrodders' Lounge 11 05-04-2008 07:03 PM
Holy Birthdays Batman!!! schnitz Off-Topic 10 05-12-2007 06:12 AM
Holy Diesel Engine Batman! unstable Engine 12 07-12-2004 08:48 PM
holy wasted bearing batman dmorris1200 Hotrodders' Lounge 12 04-25-2004 11:15 PM
Holy Scam Batman!! unstable Hotrodders' Lounge 6 04-03-2003 05:15 PM
