Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holy Jesus Great God above, 'FBird-88!!!
Old 07-18-2008, 08:17 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by spinn
f bird88- that is some build, Isky cam makes 400hp with a 600 cfm holley? what mods were done to the holley 600? i like the low lift idea of that cam. the timming and superior flow keep it pulling. a simple base 350 with vortec heads, can be changed to 400hp quick. i like weiand, but why the stealth ?
what bracket is this build, 13-14 sec ?
A true 400HP dynoed engine can run a (high) 12 sec Q mile in the average car. (3200-3600lbs) Will run faster in a car with more chassis work.
This engine we dynoed had the lowly PProducts Cyclone intake manifold (performer) on it. A high rise like the new weiand stealth or edelbrock rpm should make 8 to 15 hp more.
The engine made 410HP on the superflow dyno. It had either a 650 or 750cfm Holley DP on it. Nothing special to it. Just a bolt together that you can I can do.
