Home built air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2007, 12:40 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Built this using a sears 30 gallon tank that had a weenie little pump on it. I used a HF pump and motor which I got on sale and some pipe fittings which I had and now have a compressor that runs all the tools I need to run..
Sam
Name:	shop pics tools may 005 Standard e-mail view.jpg
Old 05-16-2007, 01:41 PM
A guy I know that runs a local dairy farm bought one of those pumps last year, well the earlier all cast iron version anyway, and that thing works darn good for the $99 he paid for it, heck it works darn good at any price. He mounted it on a 60 gallon tank from a dead CH compressor and used a Marathon 23 AMP 5 HP motor with the pulley from the 6 1/2 "peak" HP motor (3 1/2 HP actually) and the pulley that came with the pump. This thing appears to put out about 14 CFM at around 90 PSI which is not bad at all, a bit of guessing using crude measurements on the CFM but I am sure it is real close.
Another good pump for a replacement on the VERY popular 60 gallon 15 AMP (regardless of the HP "rating") compressors such as the CH and similar is this DeVillbiss from Surplus center for $99 dollars also. I have one of these sitting in the garage right now still in the box that I ordered for a fellow as a replacement on another CH 60 gallon and it appears to be a simple bolt on exchange.
http://www.surpluscenter.com/item.as...-1761&catname=
BTW that is a nice neat job you did on that thing
Old 05-16-2007, 01:58 PM
Wiki Edits: 3
This one pumps all day long and never gets warm..I have a 3hp motor on it with a 3" pulley and the 14" pulley on the compressor..Turns the compressor at about 730 rpm..i have no clue as to CFM but it does hold 60 psi with my airsaw wide open and the trigger held down..spray guns work just fine..
And thanks..
Sam
Old 05-16-2007, 02:17 PM
Sam
Aluminum pumps do run a lot cooler than cast iron they work really good and seem to hold up just fine. Some of the "brand" name outfits, such as Rol-Air (very good pump), use all Aluminum for their single stage pumps because they run cooler.
Old 05-21-2007, 07:38 PM
Bought a pump? Thats not homemade, cheater.
I made my compressor from an old lawnmower engine. Pop out the tappets, replace valve springs with lighter duty springs and scrap head. Raid scrap bin for plate, layout bolt holes, make check valve and fitting. Bolt onto cylinder. Remove flywheel, bore pulley to specified crank taper, install. Assemble with 1 old farm duty motor and ta-da: homemade air compressor for el'cheapo
Old 05-21-2007, 07:47 PM
Innovation!
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 10:09 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 10:04 PM
air compressor FIREBIRDTONY Body - Exterior 20 02-17-2007 05:06 PM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 07:24 PM
