Home built blasting cabinet arm height?
Hay guys I'm about done with my home built blasting cabinet and trying to figure out how high I should put the arm holes....Its big 4'x4' x2' The shelf will be about 36" I was thinking about 3/4 of the way up my arms would be good, I'll be putting in 28" gloves with 7" collars.
Thanks |
Myself I want the shelf a bit lower for some of the larger parts. If the arm holes are at the 36 inch height it will be about rigth for most guys but since you built it yourself take into consideration how hard it will be to move the arm holes if needed..
Sam |
That is just the main shelf it has a range from 24" and up, The entire front opens so I can put just about anything into it, Heres a few shots
http://i140.photobucket.com/albums/r...v272012102.jpg http://i140.photobucket.com/albums/r...v272012103.jpg http://i140.photobucket.com/albums/r...v272012104.jpg |
| All times are GMT -6. The time now is 01:14 PM. |
