Home built blasting cabinet arm height? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2012, 08:46 PM
kobaltblue's Avatar
Hay guys I'm about done with my home built blasting cabinet and trying to figure out how high I should put the arm holes....Its big 4'x4' x2' The shelf will be about 36" I was thinking about 3/4 of the way up my arms would be good, I'll be putting in 28" gloves with 7" collars.
Thanks
Old 11-27-2012, 09:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Myself I want the shelf a bit lower for some of the larger parts. If the arm holes are at the 36 inch height it will be about rigth for most guys but since you built it yourself take into consideration how hard it will be to move the arm holes if needed..
Sam
Old 11-27-2012, 09:59 PM
kobaltblue's Avatar
That is just the main shelf it has a range from 24" and up, The entire front opens so I can put just about anything into it, Heres a few shots
Media Blasting Cabinet Help daveh Garage - Tools 4 08-09-2010 12:56 PM
Blasting cabinet clouds up cboy Garage - Tools 23 04-06-2008 09:13 PM
Blasting cabinet pepi Garage - Tools 25 11-29-2007 08:23 AM
blasting cabinet help HzSandman Garage - Tools 3 06-14-2004 10:56 AM
Blasting Cabinet suggestions eric302 Garage - Tools 4 01-26-2004 10:41 AM
